Cigarette Lighter
My poverty spec micra didn't come with a Cigarette light...wouldn't mind one for electrical gadgetry. Anyone done an install? Where's the nearest fused positive?
I have an original lighter socket to fit on mine. I'll have a look and see if I have a connector already. Yours is a preface though, so it may be different. If you're not sure than run a positive straight from the battery with an inline fuse.
My micra's the one in the description...the pic is a preface! Got it sorted though, was tucked way down the back of the headunit!
Thanks all.
I didn't use an OEM one, looks factory though. Mine had a back that screwed off to allow the socket to come forward out of the fascia.
Need a few more bits now haha. Did yours come with Fogs?
No but all the wiring was there. All I needed were the fogs, a relay, stalk with fog switch and some loom to split the power to both lamps.
