Try using something different, do you mean like a different cable, USB or something else? Because I've tried a lot of things. I'll take the center console off in the morning and have a look, what would a short look like? Sorry for the noob questionTry using something different see if it does the same thing. Take the center console off and check cable for shorts. Anything else wired to cig lighter? Tach gauge etc??
Ah right I see, will have a look in the morning. CheersYeah plug somethin different in to see if the thing your using is the problem. A short means that at some point the two cables ar making contact, for example if the plastic insulation from two wire is cut or burnt and the metal is contacting
Working now, but will probably blow againNo probs. Pop some pics up,might help
Sorry for the poor quality but there you go. It was working last night then stopped, didn't blow the fuse though?Hi wiring looks ok but could be a loose connection in the plug a pic of the back of the cig lighter holder might help?
Andy
Do you have a multimeter by any chance? If you can pick one up you can check if the two pins or cables are making contact
