I have a 97 1.1 Micra and it wont start. It was working fine up until the other day.
When I turn the key to the "on position" the oil light, battery light and airbag light come on but the yellow engine light doesn't.
The other day i was trying to start it and while the engine was trying to start, the engine light started flickering on and off.
It then stayed on long enough for me to start the car. When the car was started I could hear a clicking sound from behind the dash that sounded like a relay with a bad connection. A kind of buzzing/clicking on and off sound and when it was making this sound, the engine light was flickering with the sound. The light flickering was happening exactly the same timing as the clicking sound.
The immobiliser light above the center dash fans goes out when I turn the key so I don't think it is an immobiliser fault.
As far as i can see there are two blue relays on the right hand side of the fuse box in the car by my right knee and two more in the engine relay box (rad fan, engine cont) I swapped some relays around but still no good. I cant get the ones beside the fuse box inside the car out because the dash is in the way but i can feel them clicking when i turn the key. What are them two relays for?
Any help would be greatly appreciated as the car is sorely missed. I can't wait to figure out what the problem is.
