Cheapest Low Psi Turbo setup
Been wanting to turbo my 1 litre micra and with low boost hoping to not spend lots of money and get some more power. Has anyone seen a setup like this??
You'll get more power from the 1.3 and at a fraction of the price.
More reliable to aa there's less to go wrong
But if you really do want to turbo route you'll want to search for a small diesel turbo as they're the smallest type around.
You set the boost at the level you want but there's no point in having a huge turbo producing sub 10 psi
go for it :) the coilpack engines might be more forgiving in terms of DET resistance
At first I was thinking of putting a 1.3 in but been it coilpack I would need a coilpack 1.3 yeah? If I put low psi boost would a fpr be enough? what about ignition timing, do i have to go piggyback?? The cams are already adjustable and are both retarded 5 degrees atm which Im sure Id have to reset for turbo.
the pre coilpack ecu has an aggressive spark map apparently, it would be interesting to see if the motronic ones are any less DET prone :)
I think that I wont be going for a turbo yet, as h701micra said a 1.3 is more reliable swap, and apparently I can still use the 1.0l ecu if I keep the 1.0l head and gearbox. With the 1.0l head would I still be ok to use 95 petrol? or would DET be a problem?
the heads are the same cc (and the pistons are either dished or flat)
So would doing that swap be any use or am I just making a 1.0l with a 1.3 litre block? Am I correct in thinking the bore and stroke will be different or just the stroke?
just the stroke mate, a 1.3 crank, rods and pistons in your 1.0 block will make it a 1.3
Fitting 1.3 pistons will lower your compression....be carefull with piggy backs as i sufferd with interferance via my pre nats ecu and the greddy emanage
