ok im a nissan trained tech
on the consult 2 on a micra there isnt a lot you can do
ie engine card, current and past errors, real time, abs (if fitted) you cant tune a engine (advert says you can)
nats card is nats only
to be very honest there isnt a lot that goes wrong on a micra engine or even the ecu managent side, you get the usual ie throttle body, fuses, relays corroding and no power to ecu and that is basically it
where as newer models it is unbelievable, you have:
abs module
ipdm
ecu
bcm
airbag
dpf
fuel pump control unit
a k11
ecu
airbag (if fitted)
abs
im not trying to put you off but i had one for my previous car and it was the dog dodars but really it would only read/erase codes and real time if you dont understand the data and dont have the manual with the parameters it is pretty useless im afraid.
ie lamba sensor voltage at hot/cold rev range etc
hope this helps
