Unclip the inner door handle surround, Unclip the winder securing clip, you'll need a thin screwdriver to get in behind the handle. Then unscrew the large self tappers that hold the pull handle on. Once the door hardwear is removed you can unclip the the door card, squeese your fingers between the card and the door, find each clip and pull hard. At least one will pull out of the hardboard not the door, Pull em out with longnose pliers and refit them before putting the door card back on.
You will need to lift the card upwards to unclip the window rubber from the top of the door.
