Hey, i just recently changed the clutch on my k11 1.0.
To be truely honest, it was a nightmare to do. but if you want a hand. i can try my best to give it on here
First off, get the car on axle stands, have the wheels off, (get someone to press the brakes in so u can take them off without them spinning.
then you need to remove the driveshafts,both of them, so its more bolt undoing.
once uve done that, ur gonna need a trolley jack to hold the engine up, since ur gonna have to remove a lot of bolts and the mounts, remember to drain your engine oil and transmission oil first before doing this, your battery and casing needs to come out.
the starter motor needs to come out too.
you'll then need to undo the clutch cable thats just under the battery casing.
once the bolts have been taken off, the casing just needs prising off, replace the clutch as required,
then just do all of the above in reverse.
but whatever you do, before you put the starter motor in, remove the speedo drive and place the transmission oil in (80w/90 Typically about £4 for a litre which is more than enough), then put the speedo drive back in, and then continue with putting it back together
