CGA1 Head & CG13 Block
Just checking if a facelift 1.0 head is put on a CG13 block thats just a straight swop to make a 1275 so long as the facelift flywheel is used as it has the sensor for the coilpacks?
Also 1.0 facelift shafts & CG13 shafts are the same as its only the preface that came with the smaller shafts & lights box?
want 1.3 cams in that 1.0 head mind
coilpack head paul ?
and yes :)
