CG16 injectors
hoopdub
Club Member (Trial)
I had a N14 sunny in work yesterday 1.6 slx with a CG16 engine. i have saved the calipers for my car, i also took off the fuel rail as i thought they may well flow more that the cg10/13 one and may possible be a direct fit. any one had any dealing with these before?
also when upgrading injectors, do they flow more al the time or only under load? not up on my injectors :D
they,re metered by duration hoopdub (open for so many miliseconds, 198cc flow when held open continously) :)
Is the flow of CG14 and CG16 engines injectors the same?
And what are they, compared to the stock injectors on a 1,3 liter K11 (obviously I know the figure of the CG16 injectors mentioned above)? ;)
Thanks,
Ulrich
