Pritchard Jul 28, 2014 #1 My little micra been working fine till today but just cuts out if I don't keep the revs high Any ideas?
Kaptain Klang Jul 28, 2014 #3 Sounds like the Idle Control Valve. What year is it? Does it have the Waxstat idle controller?
OP OP Pritchard Jul 28, 2014 #4 N reg 1996 just replaced the O ring on the idol control valve as it was split but feels as though it's hunting when I drive it What is waxstat idle controller?
frank Club Member Jul 28, 2014 #5 Pritchard said: N reg 1996 just replaced the O ring on the idol control valve as it was split but feels as though it's hunting when I drive it What is waxstat idle controller? Click to expand... probably trapped idle control valve then
frank Club Member Jul 28, 2014 #7 Pritchard said: I believe that it's free frank it will open and close Click to expand... did this problem happen after you fitted the new o ring, or before ?
pollyp Club Member Jul 28, 2014 #10 wrote a guide that might help http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446256
OP OP Pritchard Jul 28, 2014 #11 Been to breakers yard and put another idle control valve in but still got the problem :/ Duno what else could be
OP OP Pritchard Jul 28, 2014 #12 I'm getting told a few different things like cam shaft sensor or a trottle body any micra doctors?
OP OP Pritchard Jul 30, 2014 #13 This was to blame, throttle body looked as though it had been butchered in the past for some reason :/ Attachments 1406732262677.jpg 54.3 KB · Views: 261
