Right so it turned out that the guy I was going to buy a 1.3 off was a Muppet and lets say pictures can be desceving! I currently have no Micra.. or car! but I still have a working CG13DE (Y)
By using the basic maths & phsyics rule of capacity ive decided to try to build a 1.6CC engine from a 1.3DE block (I am an A 2nd Year A Level A* Physics student :wasntme: )
Pi (3.14) x Radius of Cylinder(squared) x Height = CC of that cylinder! CC x 4 = Total Engine CC
CG10DE 1.0 = Bore 71mm, Stroke 63mm & Compression @ 9.5:1
CG13DE 1.3 = Bore 71mm, Stroke 80.5mm & Compression @ 9.5:1
I had originally decided to change the total volume of the CG engine By changing the Bore size, but on experimenting with numbers I've ditched the idea of a "bore-up/bore-out" and instead a stroker idea!
By using the standard bore size but changing the "height of the cylinder" (stroke) from 80.5mm to an whopping 101mm you can *theoretically* get a CG16DE, 91mm stroke would get you a "CG145DE" engine (1.45litres)
I also theorised if you changed the bore size to something marginal like 72 - 74mm (giant in terms on cylinders etc) and lowered the stroke to something a little more practical such as 91-96mm that you could gain the same gain (1.6) from a little less drastic stroke changes! I.e. 73mm Bore x 96mm stroke = 401.8cc per cylinder obsiously with this you would need to have alot of parts changed/custom and modified but I think technically speaking it might work.. lets see if I can convice the engine centre to help me try it!
Ideas, questions or even problems? post them up now
