Speedle said:if a cg13 was to be run on carbs what would the rules be on its emmisions if it was in a 1992 car before cats were needed?
i think fintting carbs to the engine would be very easy and make fitting it to a k10 stupidly simple
thers a clear reason for that59 bhp is more than enough said:yeah prob bout the same cost as turbocharging, prob a bit cheaper. carbs you can get a set up for naff all
Ian said:if you switch engines, the rules for the emissions go from the year of the engine, not the year of the car. At least so ive been informed.
