Hi all, I have a CG13 from a 99 micra in my mini (pretty much the full micra harness too, incuding NATS, but with all the non-engine bits cut off), been working brilliantly for a few months. But a couple of days ago I tried to neaten up the wiring a little (not removing anything, just tucking it away a bit) which did involve taking the ECU off and back on again, as well as disconnecting the battery for a while. Since then it wont start, it has spark, and there's fuel in the rail. The ECCS relay is turning on, and there is power to ECU pin 46 (I believe the injector supply, but could be wrong). Code reader doesn't display any errors, the light on the ECU stays on all the time. Instinctively it feels like a NATS issue, but it doesn't start at all, unlike the usual second or two then die that the immobiliser gives. Really not sure what else to check, was hoping someone on here with lots more experience than me might be able to help!
Thanks in advance,
Tom
Thanks in advance,
Tom
