cg10 tuning
CMF_rn1988
hi i was just wondering if anyone on the site has done much tuning to the 1 litre k11 engine,any information would be helpful
thanks
CMF_rn1988
gotta keep the 1.0 litre for insurance,what works well on the 1.3 then?sorry im new to micra's
CMF_Tseq
The best mod you can do to an 1.0 is to buy a second hand cg13.Keep the cg10 block and change all the rest parts with those from the 1.3.That means head,pistons,rods,crank,ecu,cluch.You will have then a CG10 which is actually 1.3 and no one will ever know.
CMF_rn1988
Do the 1.3 parts fit straight onto the 1.0 litre block or is there some modification needed?
what is the maximum horsepower for a 1.0 litre?
CMF_kneival
You could probably get 75-80bhp out of the 1.0 with exhaust and flywheel mods probably. With the 1.3 that would see you near 100bhp.
The 1.3 will fit in place of teh 1.0 same engine mounts etc.
You will need 1.3 gearbox, driveshafts, CV joints etc. All 1.3 gearbox mounts and a 1.3 shifter rod unit.
HTH
CMF_rn1988
how about cam work and porting etc.
or does everyone think starting with a 1.3 would be the best option
