I'm running a similar 0-60 time as stock 1.3s, I believe, around 12 seconds (measured on clocks mind you so not totally accurate I must admit!) stock is roughly 16 seconds iirc. I've got 1.3cams, ga16 airbox, K&N air filter, rev-limiter removal and advanced ignition. Everything else is stock including the weight.
I'm guessing it's not going to share the same bhp figures as the 1.3s, but the lower range gearbox and lighter flywheel of the 1.0 litres (pre-2000 facelift anyway) make up for it in acceleration:grinning:
But listen to the chaps above, they know alot more than me!!:blush:
