Central Locking fault
Hi there, the passenger door keeps locking and unlocking itself as you drive along. I've found the faulty part and its in the drivers door. The part is fitted into the locking mechanism, with a two wire connector coming off it.
Is this part a Central Locking Actuautor?, if it is Nissan have quoted over 200 quid.
The guy down the scrapyard has suggested that this part is fitted to every Micra albeit unused on most cars? Is this likely to be true?
The car is an L plate super s with factory fitted remote locking.
I've tried squashing the terminals in the connector and re-fitting the wiring which has helped but not cured it 100%
Regards
Mark
