CD Player -Help-
yeah that looks fine. All cd players are the same unless its a double din, which that is not. as long as you have the wiring adaptor and the airal adaptor you should be good to go
yeah that will be fine, you need a airal adator to connect it so it earths the cd player otherwise it wont work, I know from experience
even if you try and earth it through the ariel it still wont be powerful enough so split the black wire and re connect them togeather with a 3rd wire coming off so you can use and existing screw off the standard cd player to earth it i can get a pic tomorrow if its better
I cut mine up and rewired it with quality cabling to a cd player... if you notice the cables nissan use for stereo and speakers are the thinest awg grade. for quality sound good cables are needed..
but it will suffice whats there anyway.
J
Mine does'nt need the aerial plugged in, I have an adpator and it is currently plugged in but for a while it was'nt and all was working grand.
