welll, i googled for short, and knowing there no cuts in the wire, i thout i better double check the wire, and be the fool that i am , the ground wire to power, the power to ground, most of wasted a few fuses, and dangeror to dameragin the amp, when all it was a mix of wire, so i unpluged neg battery, hooked up remote wire to i thout was live but must be battery as it came on without ing, put fuse in and went to hook up battery end to neg, disspointed when i saw the spark again, the spark that i hate but very realifed when i saw the green light, hooked up my mp3 to the red and white inputs, and it played,
but one thing, the selector where has a option for lp, hp, off, it was put in off, but still music played,but low, so i used lp, but music played but lower,
is this normal cause i am an mp3 headphone out to a rca socket.
