Carb question
superls
K10 Tuner
right a quick question about carbs.
if one was going to build a custom inlet manifold, does it matter which way around the carb is.
2 barrel carb, standard the 2 barrels run paralell to the bores, but can they sit purpendicular (at a right angle)?
cheers scott
If I understand you right your talking about turning the carb horizontally 90 degrees.
This shouldn't make any difference but you want to try and design it so that you get smooth airflow drawing the same from both barrels
The carb will have been designed to work at a certain angle, and wont work very well (or possibly even at all) too far off that.
Yes these carbs have a float chamber and will only work installed with the barrels vertical.
Think I misunderstood what scott was meaning.
sorry should have been clearer, i mean taking the carb off and spining it 90 degrees either clockwise ot counter clockwise, so the air filter is still on the top, just the carb will be twisted around.
Write your reply...
