Car not straight
ollyc98
Earlier I jacked my car up and took the wheels off at the back to check everything for my MOT friday and put some fresh springs in, after everything was reassembled I went out for a short drive to settle the suspension, anyway the car didn't look right so I've measured from the floor to the wheelarch, the passenger side are 605mm back and 600mm front but the drivers side are 570mm back and 565mm front so the whole drivers side is sitting 35mm lower, how can I sort this out? Is this normal?
Want it sorted by friday as it'll put my headlight alignment out for the MOT
Thanks in advance
youve not accidentally fitted 2 lowering springs to 1 side have you? is the car sat on dead flat ground? is there one or more springs snapped?
Sorry for late reply been out all day, yes I checked the ground with a level, the tyres are all correctly inflated (28 at the back 32 at the front) I've took it out for a hard drive and now it's only 10mm lower on 2 opposite corners.
I took the front suspension to pieces today as well to check that was all ok.
Hopefully it'll be ok by friday
