I recently bought a 94 1.3 SLX and was and until recently really happy with it. The car had trouble starting sometimes and then final wouldn't start. I've changed the starter motor after reading a few threads on here and everything has been fine.
I've had trouble with the car stalling and losing revs when idling. Today I serviced it by changing leads, filters, plugs and oil. I did this from the instruction of a haynes manual. Everything went well except getting a little dirty. I even took off the camshaft manifold and to inspect the engine. Which looked to be in pretty good condition. I took it off and replaced it using the sequence in the manual.
I thought this may help to stop the loss of power, but unfortunately its the same if not worse and the car jumps around like a kangaroo, not going over 3000rpm.
I'm pretty new to maintaining cars and would really appreciate any help offered.
Also how hard is it to change the front wheel gaitor?, because the passenger side has totally perished.
