Camshaft seal
Hi,
I have a 93' 1.0 k11 with an oil leak from the distributor... I bought an camshaft seal before removing the distributor and I couldn't find the seal. Also I dismounted the distributor looking for a seal inside but I didn't found one (I couldn't remove the shaft that commands the distributor, I imagine theres a seal inside but it's quite smaller than the one I bought)...
Do you know if I have to buy a knew distributor to stop the leak or can I repair the old one?
Also the seal I bought has 5cm of exterior diameter and 3,5cm of interior diameter? is there and camshaft seal with this dimensions in the 93 1.0? (I look in diferent sites and stores and all have that seal for this model)
Thanks for your help
