Cams
773 NME Cams
773 Rally cam Spec Nissan Micra
Inlet Open 26 BTDC Close 58 ABDC
Exhaust Open 58 BBDC Close 26 ATDC
Duration
264
264
V/L
9.09mm
9.04mm
V/C
0.210mm
0.254mm
F/L
106
106
LATDC
1.70mm
1.65mm
Rocker Ratio = 1.00 : 1
Overlap = 52 Deg
Timing = Valve timing figures, measured in crank degrees
Duration = Total duration, measured in crank degrees at end of ramp
VL = Valve lift measure in mm
FL = Valve full lift measured in crank degrees ATDC inlet, BTDC exhaust.
LATDC = Valve lift at top dead centre measured in mm
Are these the same for k11 1.4 cams or no
