they were £80 + vat when i had mine mottyWhat price would I be looking at for one of those stani?
he took 2.5mm off mine mate, so a 2nd shim neededDo I have to send them an inlet cam and do they then need to be shimmed?
they grind a different profile onto the cams you supply jk, and its quite a technical install@frank
I was thinking about autosprint camshafts so is it easy to install these cams in? Is autosprint cams are better than other brand cams.
I want to get a good and cheap upgrade cams.
N'ah, 288deg FTW
Damn, there are too many high profile cams. (Numbers and sizes) I think I will leave this out.
Because racecar
Because roadcar, (they're a special grind turbo cam).
The 'racecar' runs a significantly more radical profile that is NOT suited for the road in any way!
