i am currently changing the head gasket and wondering how to remove the bottom part of the cam belt cover i have taken off the top part and the engine mount but it wond budge with all the bolts at the bottom of it removed
yeh i had to take off the bottom pulley in the end
ALSO another question
is there a way to set the TOP cam shaft as some pillock has moved it while the head was being skimmed and now the two shafts will be out of alignment NOT GOOD!!
i lined up the timing marks when the cam belt was on to ZERO degrees on the main shaft as stated in the haynes but then i took the cambelt off, got it back from the skim and the cam is in a different position to the main crank so how am i going to align these again as i cant see any markings on the top cam
franks right theres a mark on the pully and a mark on the head you have to line up, shows you in the haynes manual, it wont be bang on tho if the heads been skimmed
