S
sir bob
Hi there all, Im in the position of having my 200sx S13 of the road at the mo, I was contemplating a rebuild, but then it struck me, why not stick the CA18DET in a micra. Ive spent about two weeks on the net looking, and all I can find is "it has been done". Heres what i have come up with so far.
Custom front manifold, as the 200sx is designed for rwd.
Electrics will definatley have to be cut and soldered, involves stripping the engine loom out of both cars, then wiring into micra, along with ECU.
Gearbox, an almera gti box Ive read should fit. Not to sure about driveshafts, as the micra has the smallest track of all the nissan range.
Engine mounts, Im hoping the will ine up, Im pretty sure that the front mount will have to be modified.
The main things that are causing my head problems so far are the engine mounts and the driveshafts, once Ive cleared these up and I can see that the project would be feasable, then Ill pick up a scrappy micra and start. Seeing as the CA18DET's are becoming cheaper this is something that should interest a lot of micra owners. With mild tuning the engine can push 250 - 270bhp, thats 150 brake per ton in a micra Any help is really appreciated, Im sure that if this can be done using mainly of the shelf nissan parts, lots of people would start to get interested.
