Yeh it'll start and run with the timing at its limits as Amy says, and you cant really put it in at 180 degrees unless you somehow jam the rotor arm on backwards...
Try double checking the HT leads are in the right order, 1.3.4.2 from the bottom right as you look at it, and the LT wires are all connected.
