Hi,
i use my K10 micra for long distance travel to work (90 miles/day). I don't speed to much although it is tempting. I heard the engines on these cars start to burn oil after a long recorded mileage. I have heard that the piston rings can wear out and need changing but i also heard that a washer in the fuel pump on some other makes can go and start mixing oil with the fuel mixture.
so far its done > than 71k on the clock and not given me a problem . I change the oil every 15k hoping it will last long but I just wanted to ask others who own K10s' if they have experienced an oil burning situaton and if so, what were the common problem(s) they found.
cheers
Mani
cheers
Mani
