dandank11 Dec 4, 2012 #1 Hello will the sr front bumper fit the 2000 plate micra ? And will the 1997 rear bumper for the 2000 plate micra?
Belly93 to turbo or new lump :/ hmmm Dec 4, 2012 #2 the sr front wont fit there is a reason why i just cant remember lol but the rear should fit, front can be made to fit if your willing to swap wings headlights and bonnet too
OP OP dandank11 Dec 4, 2012 #5 Any Ideas on bumpers that will fit or how could I mod the standard one to look jdm
OP OP dandank11 Dec 4, 2012 #7 http://item.mobileweb.ebay.co.uk/viewitem?itemId=281028716654&index=3&nav=SEARCH&nid=87745310797 Would that fit? It looks close enough to the sr ill prob cut the grill out but then ill need the fogs
Chogy Dec 5, 2012 #9 dandank11 said: http://item.mobileweb.ebay.co.uk/viewitem?itemId=281028716654&index=3&nav=SEARCH&nid=87745310797 Would that fit? It looks close enough to the sr ill prob cut the grill out but then ill need the fogs Click to expand... that one fits the facelift micras with the larger headlights. As long as you have a facelift front that one will fit
hoodedreeper Ex. Club Member Dec 5, 2012 #10 The rear bumper will fit to fit an SR front bumper you'll need to change the bonnet,headlights,grille,wings and possibly the slam panel?
CraigIC Dec 5, 2012 #11 Yep hoodedreapers right, plus.. hoodedreeper said: ...and possibly the slam panel? Click to expand... http://micra.org.uk/threads/pre-face-lift-conversion.53058/#post-543455 - this thread tells you everything you need to swap so you can double check See the post I've put up in that thread, as you will need that bar too (circled in yellow)
