Brake disks and pads
Hi all,
Was previously thinking about changing brakes on my 1 ltire to 100NX or almera but had a rethink as its probably a bit overkill to be fair. Can anyone suggest a good pad to use? also has anyone used upgraded disks (brembo, black diamond) before as mine are due for being renewed.
Cheers everyone, take it easy
Kyle
Hi all,
Kyle
Im using tarox drilled and grooved solid disks and green stuff pads tis good enough for my 1.3 :)
As a daily. Standard discs, fresh fluid and a mintex pad will see you right. If you fancy a step up then try green stuff pads/ mintex m1144's. With a vented disc and braided lines
