Bosch air mass meter
Hi ,Message for Ed,can I take you up on your offer for the air mass/meter insert for the Bosch type body as previously dicussed on here?,let me know how much £ etc,if your not to far away I could travel or do a post if distance a problem,if its a swap if you could send as cant really do without car even though its running badly.
Just a general note for folk on here with throttle body trouble,1)The Almera type sensor doesn't work on the Micra even after swapping the air temp resistor thing from the Micra into the Almera type,it seems to mess up the signalling to the ecu and throws up 2 fault codes,2)The Terrano type air mass insert is completely different and will not fit,period,the connector block facing is very different and physically wont fit,the contact pins are also different and cannot be modified to fit in any way.So dont waste well over £100 like I have on sensors that will not work. £59 plus post Almera and Terrano £40,both off E-bay.
If I had owned a crystal ball i would never have bought a facelift Micra (2000) on,I have had loads of bother despite it having a full Nissan service history,these later ones don't seem durable on several of the components and I have two Nissan breakers confirm this for me saying the electronics/management systems are over complicated and frequently fail,the starter motors on this type are also suspect(went on mine) and are very,very expensive(£222)Nissan only part supplied from Denmark.
Another thing I've noticed even when it ran well when I bought it in January, is they arn't as quick as the older one litre even though they have a bit less power,Iv'e had two M reg ones pass me on the motorway despite me caning mine to try and keep up,they just sailed away into the distance as did an N reg one on a dual carrigeway driven by a young bird near the lakes !
(look forward to hearing from Ed)
