Ok for the Turbo Gurus and non turbo gurus with knowledge, from the Turbo Gauge where do i connect the piping for the turbo reading? i have an idea but want to double clarify!!
J
J
Make me one neil
Are those John Guest fittings?
J
I'll pm you budFranks one would be cheaper mate...........mine has about £50 off parts there lol
What I can sell you tho to bolt onto franks block for the boost gauge is a flow restrictor push fitting (top right on the silver block), most boost gauges come with a t-piece with it built it to stop erratic flickering off the needle, but this is better if you want it all neat on that manifold block
Item number 161069119573 is what your after ... your dump valve will then join with a short piece of silicone tubing.
Boost gauge piping should come from your vac lines. T into those
That link is what you should avoid. Dont cut holes into silicone pipes it weakens the wall and is a potential failiure point
Nice one Andy, you knew what was bothering meWhat neil said. All goes to the vac lines on the manifold
Hope it makes sen s e
Ade may have a breakdown
I know you too wellNice one Andy, you knew what was bothering me
Sent from my HTC One S using Tapatalk 4 Beta
