Should be picking it up on Friday this week.
About 6 minor things will be all fixed at once, including:
- Gearbox filler plug was ceized on, fix and replace.
- Fuel leak out of 1 runner.
- Oil leak out of new turbocharger.
- Possibly new coolant leak out of water pump, won't be anything serious though, water pump is very new.
- Look for any other oil leaks and fix if necessary.
- Hmm forget what the 6th thing was..
Then I will basically drive it straight over to be registered. So should have it on the road running reasonably smoothly quite soon.
2" Exhaust tip will be replaced with 2.5" straight after also.
