My 93 1.0 K11 finally decided not to start this morning- it was a bit weird- it didn't seem like a dead battery as it was still churning the engine over (not slowly like when the battery really is nearly dead). Even trying jump leads to my dad's Focus didn't change the turn over speed of the starter- eventually, after about 2 minutes it finally started. Does this sound like some ignition/battery fault, or perhaps a throttle body fault- can anyone suggest what it might be or what I need to check? The plugs and leads were replaced in Feb and apart from the sticky starter pinion a few months back it has been fine. Cheers
Just been out to try it now and it started fine- like normal, with just a quick turn of the the key. It's all a bit strange to me!
