back seats
G
gazieb
any1 know how to take the bottom part of the back seat off so you can place seat covers on ?????????:suspect:
undo the two bolts at the back of the seat, then there are two catchs at the front corners that need to be popped out :)
its a bit of a pain, mine was. you may find it easier to take the back rests off first :)
definately take the backs off first. well worth it as it reduces the major hassle to not so bad hassle...
yea then give the front of the seats a good rench to unclip them....
run some RCA leads while you have the seats out :)
For car audio - although that depends if you want that or not! You wouldnt need just RCA's, you'd need power wiring too.
yea i ran my audio leads down the middle of the car which should reduce interferance,
i ran some extra wires while i was at it incase i want to add an extra amp later.
hey g_man i signed up a while back but it wouldnt let me log in or re-register so i had to register from a different computer
