iv got a universal back box but will it fit?
i was thinkin i would have to cut an weld it to fit am i correct? has anyone fitted one b4 just to give me a few pointers
thanks for any help
dan
You will need to weld up some hangers, and get it welded onto your existing pipe mate, you could always just use a Uclamp that would do! Welding is safer tho m8!
just cut the pipe to where you need so thew exhaust will fit when welded you should have a bracket or brace if not on it stainless steel juts grind your original exhaust hangers off and weld them to ur new back box so they will fit in your original rubbers then just weld your uni box to the existing pipe
