m1cR4 said:Im looking at the ashley exhaust system, its the full system and connects just below the 1st cat(under the manifold) it replaces the 2nd cat im just wondering with the 2nd cat removed has anyone had any issues with the emission test on the mot ?
thanks!
paul (polly) had problems even with a new cat iircCars with a decent secondary cat that is in good condition will easily pass an emissions test. Most people hit a problem as they are using an original OEM cat which is 15years old and well past it's best.
Been told theres new MOT regs this year, and they require catalytic converters factory fitted, anyone mot'd there car this year with an ashley (or similar) system fitted and cat removed had any problems?
Not sure what type of catalyst Paul uses, (I believe Paul did once have a rolled metal matrix type at some point?). To be honest, it's a mix of using an efficient modern catalyst, (ours is a 200cpi metal matrix type), and having adequate mapping. IMO the OEM type center cats are not good enough on their own anyway.
We pass every time with emissions very close to zero and we can bimble in at 30mph, let the car sit and still pass with ease. Before it was rag it to within an inch of it's life and test immediately or fail and even passing was borderline.
