where are the ARP bolts better and how do they enable tightler clamping? as the bolt is only as tight as you tighten it and is still only as strong as the thread in the alu block, the ma bolts arent stretch, so i would have thought if thery were torqued to a set figure how do they have less of a clamping effect then the ARP ones?
Autodata considers that the car makes about 50bhp/L not 200+.
Your still missing the point, its about over engineering, as opposed for just making do, however there are some areas (such as con-rod bolts) where I consider ARP essential, and a significant improvement over stock.
i see some really valid points there duncan, if you were building a engine from the ground up, with all new parts, and it was intended to have any sort of preformance then its really a no brainer to use them especially if there were similar in price to the oem unit, my case was there not 100% necessary for every engine on the road.
ed the link as far as i can see is in relation to big end bearing bolts, which i could sort of justify the need, but im still not convinced by head bolts/stude, ive seen lots of engines in my uncles garage and my dad bought a transit engine where the timing belts/ chains etc have snapped or had trouble, it bends valves, rods, cams, the engine my dad bought it broke the aluminium rocker box on the head, you caould actually see where the piston had left an indentation on the head, but the head bolts wernt broke or even damaged or bent.
