Anti roll bar clearance?!
When I had my car on the ramp the other day I noticed the anti roll bar is very close to the shell. Anybody else have the same? Could be the cause of the knocking noise.
Cars being too low can cause a knocking anti-roll bar but yours looks ok :/
I hit a pot hole at about 90 on a motorway the other day and I thought my wheel got ripped off it sounded horrible!!! Got a squeak from the passenger side from then, pretty sure it's the top mount.
When does it squeak just generally?
When cornering, when hitting a bump?
Check rear engine mount. Mine was loose and caused a loud squeak over bumps . 3 bolts.
Sent from my HTC One using Tapatalk
I'd agree with top mounts
Try wishbone bushes and anti roll bar bushes too
When I jacked it up to change the wheels over, I grabbed the strut and gave it a good wobble and there was a bit of movement so I'm going with top mounts.
