Hi
this evening I filled up 41L in the tank at the fuel station, the maximum I could.
Then, back into the car, closed windows, without starting the car, I noticed that it smelled fuel VERY strong. This problem already happened once when I filled the tank up to the max; like I've done this time.
Then my car started without problem, I just noticed that fuel gauge on the dasboard has decreased a lot compared to the trip I've been doing tonight once back at home. What do you think? Faulty fuel hose under the backseat? Doest there is any joint under the backseat that could be damaged and need replacement? Do you have advice about which things to check? Any parts from the fuel pump known to be dodgy?
PS: There is no fuel leaking under the car on under the bonnet where the fuel filter is.
Thank you !
Thank you !
