Another Question - Tapping Noise/Vibration
Andy_S
I Love Booooooost!
ive had this for ages but ive never actually bothered about it. The drivers door when shut rattles on idle or when the car is moving and theres vibration. Now its nothing loose on the door hinge on the actual car. Im not sure about anything on the door side of it loose. Just wondering if anyone has any ideas. Ive checked the tightness on the door hinge and its tight.
I would have said it was the door hinge, I replaced mine and it got rid of one the most annoying rattles in my car. how did you check if it was or not?
the hinge is secure as i tested it with a screwdriver by tightening up the screws and pliers pulling on it and pulling is clockwise etc and wount move. :)
are you sure it's the door? my bonnet is slighty loose and rattles when i'm at the lights, however the sound comes more from the bottom of the car more than anywhere else.
found the problem. I little screw on the door which is near the bottom of it. It was loose.
