Another pic request / question :)
FarrellK11
hello! i have found a set of wheels that i like that are 15x8 ET15, i was just wondering how much poke i will get from them? maby a pic showing similar size and offset :) and also i would like to lower my car 50-60mm aswell, would this create big problem with these wheels? i realise there probibly will be some pulling and stretching involved but i dont mind a little hard work :p and last thing, any recommendations on tyre sizes aswell?
thank you for your time :)
well there is 38mm more width either side of the wheel + 30mm more ET, so thats 68mm more wheel poke than stock :eek:
A little research has shown that it could well be do-able
http://www.willtheyfit.com/index.ph...er2=15&wheelwidth2=8&offset2=15&Submit=Submit
Change the new tyre size and you'll get an idea of how different sizes will work. I'd guess that the shoulder of the tyre would be about 30-40mm further out than the shoulder of the stock tyre size. with the 165/55s
165/50 for rather a lot of stretch
http://www.tyrestretch.com/8_165_50_R15/
175/50 for a bit less stretch
http://www.tyrestretch.com/8_175_50_R15/
185/50 for sensible stretch, but lots of tyre wall
http://www.tyrestretch.com/8_185_55_R15/
195/45 for slight stretch/straightish sidewalls
http://www.tyrestretch.com/8_195_45_R15/
okay cool thanks :D but how much will that be poking out of the arch? just so i know if i need over fenders or if i can just pull my arches :)
wow! thank you for all of that! :D im not keen on stretching the crap out of the tires so them last ones look pretty good :) im still getting used to wheel and tyre sizes and stuff so that was a big help :D
These are 15x8 Et 0, so they will stick out 15mm less than this. The tyres are 195/50 15. So with smaller tyres and the 15mm less poke you can probably do it.
http://www.micra.org.uk/threads/my-little-1-0-16v-facelift-from-italy.35923/page-2
well im quite new to this, just thought that if i asked around, you lot would probably be able to find some better pictures, i have searched for myself but it seems to be quite uncommon and the pictures that i do find often don't specify wheel specs, how much the car was lowered or what problems they had... just thought id make use of my resources ;)
