Almera ecu
does anyone know if an almera ecu will plug into a 1275cc micra engine. I ve been told if your using the 1.6 injectors then its also worth putting an almera ecu which apparently plugs straight in??
Since the K11 ecu consumes so much less air per rpm due to its smaller engine the Almera ecu really is not suitable for driving the CG13
