Almera Coilovers
hoodedreeper
Does the Micra use the same struts/susp legs as an Almera? Has anyone fitted coilovers from an Almera before? Or if anyone knows the dimensions of the Almera struts?
what are front k11 struts compared to a k10? because rtlykubi ( i think thats how you spell his username) has got polo6n coilys on the front of his and just had to drill the top strut out a bit i think
totally different mate, the top mounts on the rear are at about a 35 degree angle and the shockies sit at an angle the fronts are nothing like the k11s and like said, almeras have 3 stud at the front while the micras are 2.
Fronts will fit but not sure about rears since the suspension setup is quite different but certainly possible.
