Alloys
C
CLK230K
:glance:Hi, I'm new to the Micra club, I am in the middle of acquiring a K11. I have been searching ebay for a wheel upgrade, I found some new 14" alloys (14"x5J,100mm PCD, ET45?) item no.7959631510. Will they fit? I'd appreciate some help.
It sounds like they should fit, all you have to check is the center bore (59.1) and the tire dimensions so the overall diameter of the wheel and tire is close to stock so it doesn't affect your odometer/speedometer readings!
For checking tire dimensions try this site it is quite helpful!
http://www.miata.net/garage/tirecalc.html
Hope this helps!
