think you need some wheel spigots
http://images.google.co.uk/imgres?i...firefox-a&rls=org.mozilla:en-GB:official&sa=N
some info there mate
yh thast what there called !! thanks m8 going from my 13" to corsa 15" larger centre things
Wait...do you mean that they dont fit the hub, cos when i tried astra ones they would go on becuase the bore size is too small
Therefore you need to drill out the bore to around 51mm iirc
I had to do this and it works fine
but apperently the micra has a bigger bore then the corsa?
Thats what im saying as the Vauxhall astra ones didnt fit mine as the bore sizes are too small therefore dont fit the hubs (but will bolt on) :glare:
ok thx..so what do i need to do im so confused i just want these 7 spoke sxi wheels on my bloody car!! stupid drums X(
Its not the drums...its the centre bore of the alloys
I have the tool that can do this as mine were vauxhall as well, its basically a holesaw and an ally template which i got made up at work
You can try a few engineering places and see if they will do it for cheap...but i was looking at £80 for the set and no way was i paying that
You basically need to bore out the centre of the alloy 1 or 2 mm, but it still needs to be balanced, no angle grinder etc lol
kl im an engineer so ill take em to work an take small cuts .2mm t a time of the internal diameter till they fit CNC rotory tables for the win XD
the fronts fit fine though no play at all :S
Micra K11 spigot rings should be 59.1mm ID. If you're getting the above symptoms then it's possible these wheels have the old spigot rings in two of them and perhaps do not have spigot rings in the others. The ID of a Vauxhall Corsa spigot ring is 56.6mm, so this could offer an explanation of the wheels not all fitting. I would suggest measuring the ID with a vernier and seeing what you have and going from there.
All the best & a merry xmas
