Air Corn Question
CMF_Peter Felix
"Hi Folks, Just was wondering does any body know what's a condensor Fan mean ?? & waht it looks like (may be post a pic) Also the purpose of it & is one instaled in the Micra ??
If your car is airconditioned, open the bonnet (hood) of your car and look in front of the engine. You will see two fans one is for the radiator and the other one is for the condensor. To check if the condensor fan is working, start the car, put the airconditioner on check if the fan is working. If the fan does not come on first check the connector (mounted on the housing / shroud of the condensor fan)and re-connect it. If this doesn't work your fan is probably busted and you will need to replace it.
Cheers - Peter
