need advice on what kind of management system most suitable for k10 ST...
regards.
JBK..
regards.
JBK..
What for... Fuel? Spark?
Mine is going to use the "aldon amethyst" its a fairly new bit of kit. That only does ignition advance for boost.
It runs carbs and just upgraded ignition system throughout (new coil, leads)
Subaru micra going on a Megasquirt system
Megasquirt looks to be cheap if you build it yourself, around £210 delivered.
all you need is solder, a soldering iron, a cheap multmeter, anti static wrist strap and an IQ in double figures
