Has anyone any tips on how to adjust the doors? Can you?
They need going up a bit
cheers.
this seems to happen to a lot ok k11's particularly early reg 3 door variants, as was said a set of better quality hinges from a scrap yard is the cheapest, easiest way out![]()
the bottom door hinge/chassis mount can be slid along slightly to adjust the door resting angle to align the lock mechanism. i loosen the upper & lower hinge/chassis bracket, lift door at new angle, retighten then check fit
the A pillars have got a locating boss that stops you adjusting the hinge btw, i always "reset" the doors by using a plank of wood against the sill :wasntme:
