AD22V calipers
Hi guys, i'm tired of searching and i never get to a conclusion. I bought these calipers (ad22v) but i ran into a problem they are not a direct fit as most people say, the discs don't have the same bolt pattern in any nissan model.
What do i do to fit these on a k11?:unsure:
And do they fit on standart 14" micra wheel?
64411
Do you feel diference in pedal travel? And do you uses the ad22vf calipers holders? Ou standart micra ones?
Enviado do meu MI 8 através do Tapatalk
Just só we're clear, ad22v calipers are the 280mm from Primera right? The ones with 54mm piston
Im using the Micra ones. I got them from a sunny gti.
The sunny gti ones are 257mm discs with a 54mm piston. If the Primera ones bolt on id Just get a sunny gti brake disc.
